• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods
      » Hardware Mods » Push a G4 gigabit farther question.
Page 1 of 2 1 2 >
Topic Options
Hop to:
#473258 - 08/25/07 12:17 AM Push a G4 gigabit farther question. [Re: Intruder]
mrbit Offline
Ok I have upgraded a G4 gigabit  model with 2 gigs of ram and the Gigadesign 1.4 with L3 cache and have the 9800 pro in there.
Now, that said, I still want faster graphics IF I CAN GET IT.
I am willing to change out the logic board but do not know if the higher speed logic boards posts mystic will fit although I am willing to fabricate a solution.
I also realize if I go to a ddr lobo than I will sell my ram and get ddr.
I am running OSX and it runs great, but again I am after more graphics performance as I do not thing the 9800 is being used to its full potential.
Thanks for any suggestions or help
Top
#473259 - 08/25/07 12:29 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
mrbit Offline
I should add that I have the dual 1.4 ghz L3 Gigadesign cpus
Top
#473260 - 08/25/07 12:32 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
TCPMeta Offline
MacModder
Theres all kinds of cards you can toss in but some need to be flashed.
If you have to change out the motherboard your best bet is to get a hold of a MDD or a G5.
Some reason the "secret" site for editing video cards for macs has rejected my membership so I have no idea what is the fastest compatible card that will work. Just look at a card you would like to use and google for a mac compatible card or see if theres a flash hack for it.
To live is to let die
Top
#473261 - 08/25/07 12:48 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
mrbit Offline
TCP thanks for the reply I think the bottle neck is with the slow AGP 2x on the board.  THe vid card is the ATI 9800 pro 256 MAC edition, that was a pricey card so I will stick with it.  I think the highest I can go per gigadesigns site on my dual 1.4 is a quicksilver 2002 board.
Would a QS 2002 board fit in the gigabit case?
Edited by (08/25/07 12:53 AM)
Top
#473262 - 08/25/07 01:42 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
zenstate Offline
Loc: Vancouver, BC Canada
You are exactly right about the 2X AGP being your bottleneck.  Don't expect AGP 4X to be twice as fast though.  In my experiences its maybe 1.5X faster.  A 9800 may even be overkill for AGP 4X so buying a new video card will just be wasting money.
If you are comfortable doing a bit of case modification you could get a QS board in there.  The main boost you would get with a QS board is the 133MHz bus vs. the 100MHz on your Gigabit.
Hope this info helps..  good luck in your quest for PowerPC speed.  I myself have a real thing for dual PowerPC systems.  You could almost say they give me wood.  HAHAHA
2.94TB Total Storage
Top
#473263 - 08/25/07 04:23 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
maestro Offline
You havent said why you want faster graphics.  Games?  If so, you need a new machine.  For pro apps though, you should be just fine, unless you are using Motion, then you still need a new machine.  You wont get much faster unless you go with a MDD or G5 and for the bucks, I say go with mactel.  That said, you have a very fine machine.
The QS board will not fit without some mods and to be honest, it is on the whole, cheaper to buy the whole machine as they are going for around 200 bucks right now.
Top
#473264 - 08/25/07 04:37 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
zenstate Offline
Another thought..  if you're determined to get AGP 4x by adding a new board then you're better off going with a Digital Audio board.  It would fit in your case with less modification and still has the 133MHz bus.
Although a DA doesn't take DDR memory it doesn't really matter on a QS or any G4 tower that took DDR ram.  Why?  Because the system bus isn't fast enough to allow the memory to run at 2X the speed.  DDR memory is a tad faster on G4's but not even close to enough to make it worth replacing all your memory.
Is the memory PC133 or PC100?
Edited by (08/25/07 04:41 AM)
Top
#473265 - 08/28/07 08:46 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
mrbit Offline
thanks for the reply, i love to mess with hardware and take old machines and max them out, its fun.  the ram is pc100m, so the DA will fit better than a QS?
Top
#473266 - 08/28/07 08:54 AM Re: Push a G4 gigabit farther question. [Re: Intruder]
mrbit Offline
Thanks for the reply, no not games... i have a PC game rig that i enjoyed putting together while saving up for a mac pro some day.  for now the pc runs a liquid cooled e6400 OCed to 3.4ghz and ram to just under 1k.  I love G4's and cannot help to want to max them out and experiment with them.  I wish I were more familiar with them, thus the questions.  I already put good money into it via the chip and video card.  I just noticed the cpu getting tapped much more than i expected and then i saw that the AGP was 2x and the bus 100.  So, maybe a slight push for the fun of modding.  The only issue is that the vid is AGP 2x and 4x compat and the new gigadesign chip only works with the AGP line.  So I am trying to get to the max within reasonable limits of the machine.
So the MDD or what machine is gong for 200?
Right now I use the G4 for everyday use and mainly photoshop.
Top
#473267 - 08/28/07 12:52 PM Re: Push a G4 gigabit farther question. [Re: Intruder]
zenstate Offline
You will never find an MDD for only 200 unless it doesn't run.  He was referring to the QS.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.056 seconds in which 0.030 seconds were spent on a total of 14 queries. Zlib compression enabled.
