• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » Hardware Mods » Water cooling is back!
Topic Options
Hop to:
#473053 - 08/02/07 11:42 AM Water cooling is back! [Re: Anonymous]
TCPMeta Offline
MacModder
Well yesterday the lights went out. So to keep myself busy I went into the garage and found a bunch of stuff to make a DIY water cooling kit. Extra silicon vacuum hose from my car. A few fittings. A old jug that some 6mm airsoft BBs came in. Used my cordless drill and made holes for the fittings on the jug that i'm using for the water tank. I tested the jug with 5PSI and it held nicely. Went and hunted down my extra water block for GPU chipsets and the hose fittings. Everything came together but I needed a pump. Well I found a water fall pump that I had forgot about. I had to modify the pump for the thicker hose by attaching a short copper tube in the water pump's smaller hose and put the thicker hose over and clamped it.. Best part the pump uses 12 volts. Since the lights were out and I wanted to test it ASAP I took my 9.6v R/C car battery and tested it. Works great but it started to leak around the top part of the jug on the return but that can be fixed with some Teflon tape. Now I just needed to find a way to make the water block to attach to the CPU. I made a bracket out of some aluminum and used two long screws. The aluminum has a groove on the bottom and the water block has a screw top to hold in place. The screws are going though the stock heatsink positioning holes and held with nuts.
Edited by (08/02/07 11:47 AM)
To live is to let die
Top
#473054 - 08/02/07 03:12 PM Re: Water cooling is back! [Re: Anonymous]
oojacoboo Offline
sounds scary, I can't wait to see pics of the final thing.
Mac Pro Quad 2.66 - 4GB RAM
Quad 19" Widescreen LCDs
Accessorized to the Hilt
Top
#473055 - 08/02/07 04:25 PM Re: Water cooling is back! [Re: Anonymous]
maestro Offline
Cool!  Been a while since someone ventured down that road.  Take a bunch of pics so we can check it out.
Top
#473056 - 08/03/07 02:58 AM Re: Water cooling is back! [Re: Anonymous]
TCPMeta Offline
MacModder
I've done water cooling on tons of computers. This is my second DIY setup but with a mac. As long as you check for leaks with air tests then it's good to go, If it's air tight then it's water tight.
Top
#473057 - 08/03/07 10:54 AM Re: Water cooling is back! [Re: Anonymous]
zenstate Offline
Loc: Vancouver, BC Canada
Could we call this water cooling ghetto style?  HAHA
I would also like to see some picks of the final setup.
2.94TB Total Storage
Top
#473058 - 08/04/07 02:12 AM Re: Water cooling is back! [Re: Anonymous]
TCPMeta Offline
MacModder
I'm saving the final pics for something special.
Top
#473059 - 08/04/07 02:38 AM Re: Water cooling is back! [Re: Anonymous]
zenstate Offline
Are you saying we are not special?  wink
Top
#473060 - 08/04/07 10:50 AM Re: Water cooling is back! [Re: Anonymous]
TCPMeta Offline
MacModder
No, I just want to save the final pics for something.
Top
#473061 - 08/05/07 03:45 PM Re: Water cooling is back! [Re: Anonymous]
TCPMeta Offline
MacModder
Well my pump in my Gaming PC died and I hate the ghettoness of the mac so i'm going to build a multi water cooled system. My room mate has a old fish tank and I found a cheap pump pound pump that pushes 290GPH. I might get one or two for the setup and make it run to both systems. Since the mac and PC only use water blocks on the CPUs this will work just fine. The hard part on the whole setup will be fabercating a top for the fish tank so dust and animals will stay out. Best part is the pump will run 24 hours even with the computers off.
Edited by (08/05/07 03:48 PM)
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.062 seconds in which 0.045 seconds were spent on a total of 13 queries. Zlib compression enabled.
