I'm in the market for a Quick Silver case to house the Digital Audio logic board I have on the way. Is anyone looking to sell? I would also consider a DA case.
Let it be known, I'm not looking to break the bank. Thanks in advance for any replies!
I picked mine up for $60 CND. It's replacing the modified ATX case that i bought with my motherboard. If your interested in this, PM me know and i can see how much shipping and such would be.
Loc: Vancouver, BC Canada
Originally Posted By: "Deviant0ne "
That's right about what I was looking to spend. Now I just have to find one... Would a MDD case work for a DA MoBo?
The PCI slots on the MDD's are at the top so a digital audio mobo wouldn't fit. Pretty much any Mac tower from the B&W G3 up to the Quicksilver will hold the parts for you just fine. Maybe a bit of modification might be needed but most of slots and holes will line up.
I still have my ATX Quicksilver case if you want it. It's just taking up space in my closet and i will let it go for cheap. Here is a pic of what it looks like again. It will need a power on board in order for the front buttons and front LED to work. I took the one that was there and had to put it in my actual Quicksilver case since mine was missing it.
