Hello, I've got a G4 Digital Audio that I'm upgrading everywhere I can, and on limitation (power and noise!) was the PS. I recall reading somewhere that the pins from an ATX PS won't match up with the mobo..true? False? If false, how would I splice and rewire them? Thanks!
Heres a tip. Even though you can do away with the 28volt line and use a 12volt lead I would go ahead and get a small inverter for it. I've went though two boards using the 12volt way and one didn't work at all (might of been DoA) and the other worked for about 30minutes.
