Sorry, I had to let ours go to a particularly desperate customer, however, I have their faulty one which I can use to order another one from Apple for you. Its a 360W unit, is yours a 360 or a 400? You ought to replace like for like.
Loc: Vancouver, BC Canada
War:
The pins are all the same to the best of my knowledge and his would be a 400watt as thats what was in the first gen MDD's. Not sure why they used a 360watt in the FW800 models and then went back to a 400 in the 2003 series.
Edited by (06/17/0707:38 AM)
The reason I'm looking here is that I don't see any on Ebay right now with a Buy-it-Now option, and I don't have more than $200 to get one from a reseller...
The day Iposted that link there was one for 135 but I guess you missed it. you really need to keep an eye on ebay if you want one cheaper than 200. you can get one for less than 150 for sure but you have to hunt 2-3 times a day.
