I believe it has to be a 6800gt. It is possible to flash a 6800gs, but its harder and requires some hacking of the 6800 rom because of the disabled pipelines. I don't think the "LE" is flashable to Mac. I have flashed several 6800gt's they are great cards. Definitely check with strangedogs.com before buying any other 6800. All of those flashed cards on ebay are way over priced. Its real easy to flash a Nvidia card.
Mac Pro Powermac G5 Powermac G4 DA Sawtooth G4 AGP Powermac Cube Atari 2600,
Loc: Vancouver, BC Canada
about mac_geniuses: I bought a Radeon 9600 Pro from them for a good price. Card screams for a 9600 also. 400MHz gpu and 620MHz memory which is equal to or better vs. many current cards. Mine is a genuine Apple part though.. not flashed. anyway, i'm just trying to say that my experience with them was great.
Edited by (05/25/0701:44 AM)
now...is there ROM for it @strangedogs or something like that? Yes..i know...but i dont know really where i should search on strangedogs..
So please...can anybody pickout the correct ROM for it..if there is any? If there isnt any..i probably buy the 6200 256MB for 95bucks...also a good investement..i think...
what do you think? do I should flash the above listed Asus card..or should I buy the 6200 AGP which will (i hope so) 100%works..?
hy again.. now here some links to my favourits from eBay... can anybody say me, if any of this card is flashable like this card on aqua-mac.com....you know to stick in a PC and flash it..
Instead of posting tons of links for cards just go on strangedogs and look at their rom list. Find a card you like that they have a rom for then go on ebay and get the card then flash it.
If you find a 6800GT card from say MSI the ROM to a 6800GT from XFX will work. as long as the ROM can hold the flash firmware.
hy... damn.. :'(..i couldnt buy this card...he dont ship it to Switzerland and I asked him.. so i will look later...wether there's a good card for me..
