hy.. now..i have a lot done on the outside of my mac.. now its time to mod the inside..
here's a pic of my cover which i am currently working on..later it will stay there where the DVD-Drive usually is.. later it will be painted in some cool yellow or orange UV.Spray....
on the image it looks like its inclined..but i have only had a wideAngle lens on it..
My babys:
Mac mini G4/1GBRAM Modded PowerMac G4 Quicksilver/1GBRAM/Dual 1Ghz/6800 GT FLASH Giga-Designs RedPainted G3/512MB
hm..some other idea.. its done within Maya 7..in 5min so you will understand it,but its not really professional yet...(with GI or HDRI-maps and so one it would take hours till its a good render and yes..its jpg so the quality is very bad..but in .psd it looks MUCH better..
Edited by (05/16/0703:22 PM)
My babys:
hy.. now my HDCage is finished..it looks very cool.. i have some pics...i also removed the stickers on the HD..so it looks shiny and very professional without those stickers on it.. when the mac is running it looks so cool because the CCFL on the bottom is shining inside the case..so the hDCage is glowing a lil bit
what do you think?
Edited by (05/17/0702:26 AM)
My babys:
hy.. thank you..yoe mean a cover for the HD...not a bad idea i think...very good idea...that would look also cool cause i removed the sticker on the HD..but i have to drill some holes in...so the HD gets fresh air... i am like a crazy guy planing on my inside...
thank you for the good idea
WOokie
My babys:
hehe.. yes..i wont build it..but its a good idea.. currently i am planning the inside, where the DVDDrive usually is..( i have removed mine, so i have to build there something in)
My babys:
