• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Case Mods » Painting A White MacBook Case
Page 1 of 5 1 2 3 4 5 >
Topic Options
Hop to:
#471743 - 05/13/07 07:47 PM Painting A White MacBook Case [Re: electromir]
Waragainstsleep Offline
The top case and front bezel are quite rough so look like you could just clean them up and spray straight on, but the bottom case and display housing are very smooth, but they are at least sligtly different to the late G4 iBook cases.
Any advice in painting a complete MacBook case? ModYourMac, I'm thinking of you when I ask this question. I'd like the finish to be as durable as possible.
Top
#471744 - 05/15/07 11:41 PM Re: Painting A White MacBook Case [Re: electromir]
TCPMeta Offline
MacModder
sand it with 600 grit sandpaper then paint then sand it with 1000grit then paint again then wet sand it with 2000grit sandpaper.
To live is to let die
Top
#471745 - 05/29/07 09:45 PM Re: Painting A White MacBook Case [Re: electromir]
Eulaca Offline
I signed up just for you!
I started my mod today, I took a small step and started work on the screen bezel.
Here is how i'm doing it:
1. rub down with 800 grade wet and dry (wet)
2. Using plastic primer apply two coats.
3. Apply a few layers of paint. (if you get imperfections in the colour coat you can sand down with 100 or 1500 fine grade wet and dry (wet). then respray.
    I cure the paint with a hair dryer to speed up the process as its cold in England at the moment (its nearly june and  it wet and nasty)
4. sand down the colour coat lightly with 1500 grade wet and dry (wet) so that it has a matt finish.
5. Apply sever layers of clear coating.
I am using automotive paint as they are harder wearing.
I'm going to start a log for this some time with pictures showing my progress and how im doing it. This is the first time i've done something like this so i'm unsure as to how it will turn out.
Top
#471746 - 05/29/07 09:52 PM Re: Painting A White MacBook Case [Re: electromir]
I'd be interested to see the finished product. To be honest, I don't have a compressor or anything, and I have never gotten good results from spray cans. I might just get a quote from a bodyshop.
Top
#471747 - 05/30/07 07:24 AM Re: Painting A White MacBook Case [Re: electromir]
Eulaca Offline
Just my luck, I have good weather today and i'm stuck working.
I'll try o get the insides stripped out after work.
Will also do a practice run with the battery to see what finish it gives.
Top
#471748 - 05/30/07 05:51 PM Re: Painting A White MacBook Case [Re: electromir]
modyourmac Offline
Loc: Portland, Oregon
Hey War, you know you can PM me or email me directly, if you have questions smile
As far as macbook painting, here's what I would do. First, figure you're gonna have to gut the entire machine in order to get down to plastics. So keep track of where everything goes, make a screw map, and keep it all organized. Do this, and you'll thank me later. I promise.
But, once you're down to bare plastics, I'd scuff them with 800-1000 grit wet/dry sandpaper. you dont want the surface all gouged up, you just want to take it down flat and get the gloss off it. Then, mask off things like the bottom feet with masking paer. Mask anything you dont want painted. Then, a good sandable primer would be next. several coats, and then a light sand (dry) with 800 grit, justy to smooth it, an pull off the dust. Wipe down with a tack cloth as well.
Once your primer is smooth, if you're using spray paint, you should be able to go straight to your color coats. However, if you're using something semi-transparent, I'd spray on a flat white automotive first. Likewise, if you want some sparkle, get one of those transparent sparkle coats and spray that over your white, and under your color coat. If you're going with just a solid opaque color, dont worry about it. When spraying, read the directions on the can, shake the can constantly, and work in even strokes. You'll want to put several coats on with appropriate flash times, so the paint can build up. Once the paint has cured for the full drying time (24-48 hours at least) I would wet sand it with 2000 grit, in order to get it super smooth. Then, clear coat your color. Same as paint, give it plenty of drying time. Then wet sand with 2k grit, and use a good rubbing compound to polish it out. 3M makes a good compound in a black bottle. You'll be amazed at the shine you get. I promise.
War, if you want more detail, email me directly at [url=mailto:info@modyourmac.com]mailto:info@modyourmac.com[/url]
Top
#471749 - 05/30/07 08:49 PM Re: Painting A White MacBook Case [Re: electromir]
TCPMeta Offline
MacModder
Hey Eulaca, how's it coming?
Top
#471750 - 05/30/07 10:52 PM Re: Painting A White MacBook Case [Re: electromir]
Eulaca Offline
Well i managed to destroy the keyboard today.
It was all going well until we had to remove the keyboard to double check everything. the connection didnt come off properly and destroyed half the pins.
Its 10 to 12 at night so im giving up until morning. Will try and solder the pins back on.
If i cant solder it i'm going to need a new English topcase. It's going to be very hard to find one.
Top
#471751 - 05/30/07 11:44 PM Re: Painting A White MacBook Case [Re: electromir]
Eulaca Offline
ok, i need an entire top case.... bugger
Top
#471752 - 05/31/07 03:46 PM Re: Painting A White MacBook Case [Re: electromir]
I have stacks of case parts for MacBooks Especially top cases. They are discoloured so have been removed, but many work just fine. PM me if you want one Eul. Won't cost you much.
As for screw diagrams, thanks for the tip MYM, but I could gut one of these in my sleep. It was your painting expertise I was after. I have never used clear coats on anything, but I have heard the term bandied about in various places and figured this would be a job where one (or more) would be required. Can I accomplish a good finish with off the shelf cans of auto paint?
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.060 seconds in which 0.040 seconds were spent on a total of 14 queries. Zlib compression enabled.
