• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » Case Mods » PC in g4 case
Topic Options
Hop to:
#471690 - 05/11/07 05:50 PM PC in g4 case [Re: Marocania]
zrust Offline
Ive decided to pu my mini atx pc mobo into my ol mac g4 case. After looking at some resources and planning, ive come acrooss two problems
1. The pci fan: The standrd atx psu doesnt have the power port for the fan, what do i do? (other than not using it, that is)
2.The front power button and leds:how do i connect these to my mobo?
Someone help me!:)
Top
#471691 - 05/11/07 07:56 PM Re: PC in g4 case [Re: Marocania]
Waragainstsleep Offline
I'm not so hot with front panel boards, unless your ATX board has a two pin power-on connector, in which case you can bypass the front panel board and wire it to the power button instead.
Do you know the voltage of the fan? There are usually plenty of spare 5V and 12V leads off most PSUs. If your case is from a pre Mirror Door G4, then you could probably just swap in a PC ATX supply. I presume fan speed is controlled by software via the PCI bus?
Maybe you could just swap it for PCI fan with a molex connector.
Top
#471692 - 05/11/07 08:04 PM Re: PC in g4 case [Re: Marocania]
WOOKIE1212 Offline
Loc: Zurich,Dietikon
hy..
for short: http://www.s155158671.websitehome.co.uk/winmacpcinaapple.html
here you can for sure look how he has done...U also could write him an eMail..he s very kind...
My babys:
Mac mini G4/1GBRAM
Modded PowerMac G4 Quicksilver/1GBRAM/Dual 1Ghz/6800 GT FLASH Giga-Designs
RedPainted G3/512MB
Top
#471693 - 05/11/07 11:23 PM Re: PC in g4 case [Re: Marocania]
TCPMeta Offline
MacModder
Simple fix, get a new fan or rewire the old fan to use a 12volt lead.
To live is to let die
Top
#471694 - 05/12/07 10:26 AM Re: PC in g4 case [Re: Marocania]
RedDrag0n Offline
Loc: Canada
Originally Posted By: "WOOKIE1212 "
hy..
Yeah, Steve is cool about that. Also, my website shows how to do a pc board in a mac case also.
Page 1, page 2, & page 3
Website
Top
#471695 - 05/14/07 11:07 AM Re: PC in g4 case [Re: Marocania]
zrust Offline
k, now im a little informed, but i need to know some things more.
1. Does anybody know the voltage of the fan? If i knew this, i thought i could try removing the power port from the old psu and try wiring it to one of the ports on the ATX one. And also, Do i need the fan at all? I wont be using hot pcis or anything...
2. I saw in one of the links where somebody soldered some wires onto the front button panel to hook it up to the pc mobo...Can i do the same by just soldering some wires onto the sharp metal protrudances on the underside of the panel? If it is possible, can someone tell me where each of them has to go?
3. i drilled some mobo standoffs into the case, but im having difficulty removing the old ones. Someone suggested dremeling them off, but i ont have a dremel lying around...any ideas?
Thnx for all the replies! smile
Top
#471696 - 05/14/07 11:52 AM Re: PC in g4 case [Re: Marocania]
TCPMeta Offline
MacModder
1. The fan uses 12 volts
2. I would get a new board and  two switches and make it as the power and reset. You can get the parts from http://www.allelectronics.com
3. A drill will work if you had a grinding bit. Go to walmart and buy a dermel grinding bit and use it on the drill.
Top
#471697 - 05/18/07 12:28 PM Re: PC in g4 case [Re: Marocania]
karlos Offline
The quickest and easiest way to get rid of the old motherboard standoffs is to drill them out from behind, using a 2.5mm drill bit.
Here's my work so far (http://webfusion.net.nz/g4pc).
I've run into the problem where the board hits the CDROM. The drive I have is 20.5cm long, i think i can fix the problem by using a 17cm CDROM.
Any other suggestions welcome.
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.053 seconds in which 0.039 seconds were spent on a total of 13 queries. Zlib compression enabled.
