hy..now i ve you got a PowerMac G4 you have to put the sidePanels in alcool(about 95%).. about one day in alcool and then rubber the paint off..
for the apple-logo--ehrrrmm..you ll have to take a VERY tiny card or something like that and then stick it between the apple logo and it should pop-off..
so far
Wookie
My babys:
Mac mini G4/1GBRAM Modded PowerMac G4 Quicksilver/1GBRAM/Dual 1Ghz/6800 GT FLASH Giga-Designs RedPainted G3/512MB
If you have a aul you can push it though a small hole on the back of the panel and the Apple logo should come up enough and you can use your fingers to pull the rest off.
Do not use a abrasive object to take the paint off. All it will do is scratch the panel and the lose paint will go into the scratch. Then the scratch will close up when you keep using the abrasive object. Use paint thinner and a terry cloth. It's abrasive but not enough to make paint go inside the panel. To get in the hard to reach corners use a razor blade or a pick and ever so gently and remove the paint. If it scratches then some simple car glaze swirl polish will cover it up.
If you want to go all diehard on it you could let it soak in paint thinner then wetsand it with 600 grit then move to 1000 grit and finishing it off with 2000 grit then polish it. Same trick works with plastic car headlights.
cheers for that, i shall go and get some paint thinners to try it! havent decided on the colour yet???? may do it black and leave the apple logo the blue colour and then put blue leds inside????? ;-)
but pay attention..cause when you use some thinner or something...it could blur the insde...so please be careful and try it on a corner of the sidePanel or so..
i have painted my G3 on the outisde..but the inside couldnt be done transparent..yours can be done transparent..so you also could paint it inside..
GOOD LUCK..;)
WOOKIE
My babys:
