Its a matter of taste... I commend the doom box for truly incredible work, and a much more informative description of the process (a lot of stuff will help me in my next projects) BUT>>> I've always loved Big Daddy Roth and would much rather have it. I just wish the actually had it pin striped.
That link is to a V8 but a inline 4 cylinder would be idea for a single computer case. I would have more detail like make the power supply look a distributor and have the cables from the power supply look like spark plug wires going though the valve cover into the case. For the intake manifold It could be a water tank for a water cooler. Use the same spots where the PCV valves go for the water line for the CPU and have a ram air intake on the manifold to house the radiator for the water cooler. Put the water pump for the cooler where the water pump of a car would be located. Take two 80mm fans and cut off the blades and use a belt to move around. Maybe 3 fans and make a fake alternator. Also I can make it look like it's carb instead of EFI and have the radiator to look like the carburetor.
So many ideas to make a computer case to look like a engine.
