now most of you know that i ve got two modded macs.. now my G4..has got a GigaDesigns Dual 1.2Ghz which i had to downclock on 1Ghz.. It runs stable..but i am not 100%sure,,you know 100 is 100 and not 99,99999.. so i d like to install a very simple but very efficent way of cooling..
THE SLOT.FAN .. i ve got already one..but the next will be a custom mod..
here s my little illustration..(done with Maya..it doesnt seems very good..i got better skills..but that scene was built in 5mins...but i think you can imagine what i want to show..
now i d like to install it where the zip was..
My babys:
Mac mini G4/1GBRAM Modded PowerMac G4 Quicksilver/1GBRAM/Dual 1Ghz/6800 GT FLASH Giga-Designs RedPainted G3/512MB
i even think its a very good idea... i dont know why to change the 120mm fan..i had a CoolerMaster (who sucked) but now i have installed the old again... maybe i will exchange also the 120mm fan...maybE this slotfan moves 45CFM..thats a lot..and it will cool the processor and the Power.Supply...and then it leaves the case where the CPU is..
i hope that the fan will fit..cause i havent got a DVD:Drive i will mount it there.so i only can slide it out and turn it on whit a switch i think..and i am READY TO GO..
thank you
Wookie
Edited by (05/07/0701:26 PM)
My babys:
