• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods
      » Hardware Mods » Powerbook g4 1ghz 15inch backlight for display going.
Page 1 of 2 1 2 >
Topic Options
Hop to:
#471586 - 05/07/07 12:50 PM Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
wisdom_105 Offline
hi i am looking in to replacing a backlight in my display for my powerbook?
anyone no the parts or where i can get them ?
and maybe a guide or any help is appreciated  smile
thanks
rob
Top
#471587 - 05/07/07 03:03 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
reLAXER564 Offline
try ebay first
iMac G5 rev b. 1.8 2gb ram
Red iBook 14'' 800 Mhz G3
12'' iBook 1.07 G4
12'' iBook 600 Mhz G3
3.46 Intel Core Duo 2GB ram 500 HD
24 inch dell flat panel
Dual GeForce 8800 GTX in SLI
Top
#471588 - 05/07/07 03:09 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
Waragainstsleep Offline
Replacing backlights is as fiddly as it gets when you are swapping parts in a laptop. Getting the old light out without mangling the display entirely is no mean feat. You tend to expose the guts of the display to the atmosphere, and I can't imagine that does it much good.
Your best bet is to find the same panel which has been cracked and remove the backlight from that one. This way, you get a practice run on a display which is already FUBAR.
Don't go near any panels if you suspect the backlight too may be cracked, and don't crack one yourself since they contain mercury, and if you call environmental services, and they find the mercury levels in the room are too high, you will be sealing that room off with plastic until you have saved up the $2000 that it will cost to have the room decontaminated by professionals. This happened to someone the other day (reported on slashdot) when they broke a CCFL energy saver light bulb. Then there is the potential risk to your health. Mercury is not good for you. Just look at the mad hatter from Alice in Wonderland (hatmakers used to use mercury).
Top
#471589 - 05/07/07 04:53 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
mordaskyt Offline
are you sure its the backlight itself? It is far more likely to be the cable or the inverter.
PB G4 15" 1.2ghz - Pismo G3 400 mhz - iBook G3 500 "Jukebox"
"SawSmurf" G4 500 - Quicksilver G4 Dual 1ghz modding...
Top
#471590 - 05/07/07 07:42 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
Very good point. Spot on.
Top
#471591 - 05/08/07 02:42 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
wisdom_105 Offline
smile Thanks for your replies , is there away i can tell if its the cable or the backlight?
if it is the cable , can i replace it?
thanks
rob
Top
#471592 - 05/08/07 04:01 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
mordaskyt Offline
Well if the display blinks on and off when you move the lid back and forth, lighting up if you hold it "just right" its prob the cable. check it for visable signs of damage, particularly where it runs through the hinge assembly. Asuuming the screen does not light at all hold a lamp or flashlight to the screen, can you see a dim image? if so the LCD is fine its just not lighting up. You may find you need to purchase a replacement inverter to try before you can narrow down the problem further. Cheaper and easier than messing with the backlight and you can always return or re sell it if the inverter turns out not to be the problem.
Top
#471593 - 05/16/07 10:28 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
wisdom_105 Offline
welll its seems that when i turn the brightest down and then up it comes back on for a second then goes back off ?
any one have any idea what could be the problem?
Thanks
rob
Top
#471594 - 05/20/07 11:42 PM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
wisdom_105 Offline
hey i thinki come to the conclsuion that it is the inverter ? but what is the inverter is the inverter board or cable? how can i tell what is bad?
thanks
rob
Top
#471595 - 05/21/07 07:03 AM Re: Powerbook g4 1ghz 15inch backlight for display going. [Re: videofreeven]
Like Mord said, if you can get it to come back on by moving the screen, it would indicate the cable. Changing the brightness would suggest to me the inverter itself.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.028 seconds in which 0.016 seconds were spent on a total of 14 queries. Zlib compression enabled.
