maestro, i think i ve got the solution..the two highspeedFans..now they are on a little piece of metal.. So, the heatsink has got on each side THREE holes..so together 6..now i screwed my piece of metal in the last holes..i think i also could try out how the processor is working, WHEN i will screw the piece in the other two holes..then the two fans on the metal would be in the MIDDLE not in the back of the heatsink..
i think this could work well..or better.
What do YOU think?
thanks
Wookie
My babys:
Mac mini G4/1GBRAM Modded PowerMac G4 Quicksilver/1GBRAM/Dual 1Ghz/6800 GT FLASH Giga-Designs RedPainted G3/512MB
hy.. i think i will wait about 1week..BECAUSE GIGADESIGNS NEEVVERRR writes back.. thats what i call BAD very Bad Support... now i want that this processor works,because when i will send it back to GigaDesigns i dont know wether they will send me a new...because i have got a dual 1.2Ghz downclocked by myself on 1Ghz but they dont produce it anymore so they have to send me a DUAL 1.33GHZ with ALUMINIUM-HEATSINK.,.
so i want wait on gigaDesignds reply BEFORE i will do anything with the CPU (thermalGrease etc)
what do you think I should do..they never write back..and i also wrote that...i HOPE THEY WILL NOW write me back,,
Thanx
Wookie
My babys:
