• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » Case Mods » MY TWO MODS
Page 2 of 5 < 1 2 3 4 5 >
Topic Options
Hop to:
#471463 - 05/03/07 02:23 AM Re: MY TWO MODS [Re: antirippers]
maestro Offline
Wowsers!  That is a ton of wiring and loom in there.  I would try and clean that up a bit to get some better airflow.  Why the second power supply?
Top
#471464 - 05/03/07 03:02 AM Re: MY TWO MODS [Re: antirippers]
reLAXER564 Offline
what are the specs?
iMac G5 rev b. 1.8 2gb ram
Red iBook 14'' 800 Mhz G3
12'' iBook 1.07 G4
12'' iBook 600 Mhz G3
3.46 Intel Core Duo 2GB ram 500 HD
24 inch dell flat panel
Dual GeForce 8800 GTX in SLI
Top
#471465 - 05/03/07 11:02 AM Re: MY TWO MODS [Re: antirippers]
WOOKIE1212 Offline
Loc: Zurich,Dietikon
hy..
yeah,,..thats right..much cables..for all the lighting-stuff...
ehrm,..i will put around zip-ties in black..but not too much,because when the cables are to stiff the case couldnt close..but it should works...
@maestro: there isnt any second powerSupply...
Specs:
Dual 1.2Ghz downclocked to 1GHz(cause of overheating)
1GB RAM
120GB HD
no DVD-Reader i dont need it..but i have got tons of it
stock grahpic-card {i ordered a 9800pro then a 9600pro but i had to wait about 5months and it wasnt there so money-back)
today i will order a DELTA FFB 0812 EHE...the real turbine..about 90CFM...60db LOUD...but i need it..cause my computers cpu's are overheating when they work for 2hours 100%/100& on 1Ghz...under normal conditions it works fine...and i love my mac(s)..
Wookie
My babys:
Mac mini G4/1GBRAM
Modded PowerMac G4 Quicksilver/1GBRAM/Dual 1Ghz/6800 GT FLASH Giga-Designs
RedPainted G3/512MB
Top
#471466 - 05/03/07 12:35 PM Re: MY TWO MODS [Re: antirippers]
zenstate Offline
Loc: Vancouver, BC Canada
you need one of these SilenX fans: http://www.frozencpu.com/products/4274/f...l?tl=g36c15s550
90CFM @ only 18 db.  trust me..  the specs are accurate.  Silenx are the greatest fans made by far.  I use the same one in my dual 867 MDD and my temps are around 45-50c even under heavy use for hours.  if your system is overheating then its getting up around 70-80c.  most G4's will auto shutdown around 75c.
2.94TB Total Storage
Top
#471467 - 05/03/07 12:59 PM Re: MY TWO MODS [Re: antirippers]
maestro Offline
I would recommend Sharkoon fans as SilenX are quiet but very low air flow.  Sharkoons have the highest flow per db reading.  Ah, what I though was a second psu must be a fan plate with a thermal take fan.
Have you tried resetting the cpu heatsink with arctic silver?  I would try that first.  I cut a hole in the side of my QS where the large fan is (I have several side panels) and that increased the cool air intake.  You could also replace your cpu heatsink fans.  I would try this stuff before putting a loud fan in the case.  Also, tidy up those cables!
Top
#471468 - 05/03/07 01:54 PM Re: MY TWO MODS [Re: antirippers]
zenstate Offline
I wouldn't call 90 cfm low..  most 120mm blow an average of about 50-60 cfm @ around 25-30 db.  I consider anything above 22-24db loud and I don't think SilenX makes a fan above 20db.  their fan blade design can push a lot more air per rotation because of how its slightly scooped.
Top
#471469 - 05/03/07 05:09 PM Re: MY TWO MODS [Re: antirippers]
WOOKIE1212 Offline
from maestro:
{I would recommend Sharkoon fans as SilenX are quiet but very low air flow.  Sharkoons have the highest flow per db reading.  Ah, what I though was a second psu must be a fan plate with a thermal take fan.
Have you tried resetting the cpu heatsink with arctic silver?  I would try that first.  I cut a hole in the side of my QS where the large fan is (I have several side panels) and that increased the cool air intake.  You could also replace your cpu heatsink fans.  I would try this stuff before putting a loud fan in the case.  Also, tidy up those cables!}
Ehrm..there are some thermalpads on the bottom of the heatsink...Do you think its good to put some Arctic Silver thermalPaste under the bottom...for first i havent got some additionals thermalPads how they write in the manual.
2. i dont know if ArctivSilver Paste is better than the thermalPads...
and for last. yes i will cut with my new dremel a hole in the plasticPanel..with a fanGuard..but for first i think i should buy a second SidePanel..(mine are also a little scratchy)
...what do you think i should do?
Wookie
My babys:
Mac mini G4/1GBRAM
RedPainted G3/512MB
Top
#471470 - 05/03/07 05:40 PM Re: MY TWO MODS [Re: antirippers]
maestro Offline
Get rid of the thermal pads, those are no good, or you could say, just good enough.  Arctic silver 5 is much better as long as you apply it correctly.  Google the procedure.  Scrap the thermal pad off with some sort of plastic scraper so you dont scratch the heatsink.  You can polish the bottom of the heatsink too.  Later today, I will try and remember to post a picture in this thread of the hole on my wifes QS so you can get an idea of how it could look.
Start with the pad removal and AS 5 first.  Get a better fan or cut the case side next...pending on how much dough you want to spend.
See how that affects everything and go from there...By the way, simple things like room temp, keeping the surrounding area clear, cleaning dust out also help too, and they are FREE!
Top
#471471 - 05/03/07 06:12 PM Re: MY TWO MODS [Re: antirippers]
WOOKIE1212 Offline
hy..thanx a lot..
yes the hole in the side would be very good and also would look very COOL..
for second..yes it could be the pads CAUSE at the first day the processor runned about 7hours stable @1.2ghz @about 90DEGREES:..thats perhaps the reason why the thermalpads are dried out..
the only thing is HOW TO REMOVE the heatsink..i dont know..i didnt used the manual cause the false was in the box..there are only screws to remove the two fans..but how to remove the heatsink,i dont know..
thanx...please write back fast
WOokie
My babys:
Mac mini G4/1GBRAM
RedPainted G3/512MB
Top
#471472 - 05/03/07 07:00 PM Re: MY TWO MODS [Re: antirippers]
WOOKIE1212 Offline
hy..some pics of my new STICKER @ sidepanel:
http://imgbox.de/?img=m45857p208.jpg
http://imgbox.de/?img=s16752e208.jpg
My babys:
Mac mini G4/1GBRAM
RedPainted G3/512MB
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.049 seconds in which 0.026 seconds were spent on a total of 14 queries. Zlib compression enabled.
