iBook appletv mod [Re: gelermiorio] #471409 04/28/07 09:47 AM
E
eNaq Offline OP
E
hi guys! im new here. i have been a regular viewer of some of the topics and i have seen some real impressive work. finally, i am registered.
i am wondering on software modding on a g3 ibook, since this does not involve hardware and is rather misc.
is it possible to run the appletv software on this ppc g3 ibook? as the apple tv has a intel processor, can i change the binary somehow? also, where can i find and download the appletv software?
thanks.
-eNaq
Re: iBook appletv mod [Re: gelermiorio] #471410 04/28/07 12:58 PM
I
ipodphoto Offline
I
Wel i don't know if you could run the software on your ibook. However, you can run FrontRow on you ibook, which is basically the exact same lol
Check this site http://andrewescobar.com/frontrow/
it has a very easy guide on how to make FrontRow run on ppc machines other than the iMac G5 (as it was the first and only ppc to come with FrontRow and remote).
Hope that helps.
eMac - 700MHz, 40g, 1gb
Mac Mini - 1.42GHz, 80g (250G ext),1gb
20 " Apple Cinema Display
30G ipod photo
ipod touch - 16 Gig
Re: iBook appletv mod [Re: gelermiorio] #471411 04/28/07 04:03 PM
W
Waragainstsleep Offline
W
Unless you can extract a copy from Leopard whic has Front Row built in for PPC and Intel Macs, regardless of hardware. Plug in an IR receiver and it comes straight up.
Re: iBook appletv mod [Re: gelermiorio] #471412 05/01/07 06:14 PM
W
W
I should add that the only way to change software from a PPC binary to an Intel one is to recompile it. So unless you have the complete source code, you aren't going to get the ATV software running on any iBook.
Re: iBook appletv mod [Re: gelermiorio] #471413 05/15/07 11:39 PM
T
TCPMeta Offline
MacModder
MacModder
T
Has anyone tried the DD dump of AppleTV  on a PPC CPU? It might have both coding (Universal).
To live is to let die
