[censored], my memory is PC100, I didn't even think about it before because I swore I had PC133. So I just bridged the two connections from the front with some wire for the time being until I get some PC133 memory, thankfully I had one peice I could test with. Problem was, it didn't show the correct speed in the profiler, it still thought it was 100 MHz bus. Is there a way to change this? I have a FastMac CPU upgrade that'll run at 1.467 GHz on 133 MHz FSB.
Theres a mod to install a dip switch to rasie the FSB. Thing is most systems that have 100MHz FSB can't run 133MHz and only been able to reach i think 112MHz.
I know about the dip switch mod, I just didn't have one around and RadioShack didn't have any. The system seemed perfectly stable at 133 MHz for the time I tested.
