It's simple as cake. Buy a cheap-o solder tip and grind it down to a sharp tip. To help things out take some construction paper and cover everything except where you want to solder so it will protect your board from anything bad dripping/spilling etc etc etc...
Since the logicboard will be upside down the pinout for the USB will be backwards.
