I actually, put a small usb hub in there. I cut the bezel a bit and ran the wire to a internal connection on a usb 2.0 card i was using. You could even run it to the outside to a stock one. Get creative and make your own.
I would go with the USB hub idea that maestro was talking about. Easiest way on that is to cut the ZIP slot bigger and use hot glue to hold the hub in place.
