Hi folks, I'm not sure if I'm posting this question in the right place. I'm starting on a case mod and will be moving a G4 Dual 1.25 MDD Mac into a Lian Li PC-60 or PC-7 case. I'm looking for info on how to remove the logic board. I've removed the heat sink but don't know how to remove the smaller processor daughter board that sits on top of the main logic board. The daughter board is plugged into a black plastic strip with two spring-like clips. Could anyone could give me some tips or point me to a how-to for this? Thanks
good point, I think I read a post here in macmod that might help you... Unfortunately I don't remember where, you can browse through the case mod section of the forum... good luck!
