It seems that if (when ) these MBP start showing up on ebay would the swap in my al pb simple? I mean it seems like the dimensions are the same and the ports are in the same places...
Confused. You want to put a MBP logic board in your albook?
It would be alot of work, and you'd need the right card cage, left I/O board and with the exception of drives, everything in the bottom half to go with it. The LCD should run though.
