Does Anybody know how to make windows server 2003 read the ext3 filesystem (also known as extended with journaling) Iv tried a few but nothing seems to pick it up.. Any Ideas?
Are you trying to use windows server on an HFS formatted disk, or just simply access the contents of an HFS formatted disk from a NTFS/FAT formatted disk with win2k3 installed?
If that ladder and you don't have a mac running the HFS disk so you can access it via a network, the options Krusher117 gave you should work nicely. If you are talking about the first option, I have no clue, I am not even sure thats possible.
