Does anyone know of a way to use an iMac G3 as an external display? I have one sitting around, and a display seems like a good use for it. I know it would involve taking the iMac apart and finding some cord that feeds the display its video.
If I can't turn it into an external display, option 2 will be a fish tank...
The CRT on the tray loaders has a DB-15 connector inside the case. This is essentially VGA with the pins arranged differently. The old Beige G3s and most Macs before them had the same connector.
