• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Hardware Mods » Rugged tabletizing
Page 1 of 2 1 2 >
Topic Options
Hop to:
#469562 - 11/23/06 05:38 AM Rugged tabletizing [Re: Dalspeeklyrep]
ANonEMouse Offline
So, I'm thinking of building several (14+) 17" ruggedized MBP tablets.
Here are the requirements that I will have:
- Waterproof (3 feet submerged)
- Shockproof (10 foot drop onto concrete)
- Shockproof (Hardened Screen able to be jumped on by adult)
- Sunken quarter turn latch covers over ports and battery for easy access using a tool, but impossible access without, even with a pry bar.  The port covers themselves will need to be sunken as well as the latches.
- Functional Speakers
- Functional Camera
- Functional Wireless
- Functional touchscreen (not a problem)
Here are the thoughts that I've had.
- I'm planning on using stainless steel for the case itself, because of the strength.  I will then coat it in a hard rubber shell for some shock protection, and gripability.
- Waterproofing means sealing the case, so I will need to cool it without fans.
- I'm hoping to do this in 1.5 - 2" thick, 16" wide, 11" long.
- I would like to put two buttons on the side so as to externally access the zoom feature of Mac OS.  These buttons should not be able to be pried out. (maybe using the light sensors behind holes with plastic?)
I realize that most people may not have experience with this heavy of a mod, but I am looking for brainstorming regarding the heat dissipation and other issues that people may perceive.  Please also note that I am serious about this, and have a budget to do this in, so it is not a problem to replace units.  I will also have a professional fabricator do the steel work once I have my design in hand.
I cannot give any other details about the final use of them until after they have been built, then I will be happy to show pictures, and it will be apparent as to why I have my above requirements.
Top
#469563 - 11/23/06 03:15 PM Re: Rugged tabletizing [Re: Dalspeeklyrep]
Kisin Offline
Sounds expensive... liquid cooling is my first tought, but you still need to cool the water... same with oil inmersion... perhaps a twa stage process, using liquid cooling and some sort of cooling gas to cool the water.... im concerned abouyt usability though... stainless steel, complex cooling, hardened screen... it might be too heavy to be useful... good luck and keep us posted
Top
#469564 - 11/23/06 04:38 PM Re: Rugged tabletizing [Re: Dalspeeklyrep]
ANonEMouse Offline
Ruggedizing adds weight, there's no way around that.
If I figure that it will take two sheets of 16"x11"x1/8" Stainless (rough estimate, of course, as there is a hole for the screen, and the edges that will connect the two sides) the steel will weigh 5.8 lbs.  Now, figuring a 6.8 lbs Macbook - 2 lbs for the case, we are now at 10.2 lbs.  Figuring about 2-3 lbs for internal mods and the hardened glass, we are roughly the weight of two Macbooks, which I think is acceptable.
In my research, I've also just realized that carbon fiber may be a good material to use.  I will be talking to some CF manufacturers to determine if I can get steel like strength out of it at a thickness that would be usable in the computer.  If so, I may look into it further.
Top
#469565 - 11/23/06 06:53 PM Re: Rugged tabletizing [Re: Dalspeeklyrep]
manhackman Offline
polycarbonate (lexan, etc.) may prove to be a better solution than hardened glass...
http://www.sdplastics.com/polycarb.html
>Mac mini PPC / 1.42 Ghz / 1GB RAM / 74.41GB 4200rpm 2.5" / Airport + Bluetooth / 10.4.7 / 20.1" LG widescreen
>G4 400 PPC / 20 gig / 768MB RAM / ZIP drive / 10.4.7 /17" apple SD / Back up system
>Powerbook Titanium 1Ghz / 40GB / 512MB RAM / mashed up and waiting for a good mod!
>Macintosh SE/30
Top
#469566 - 11/23/06 10:42 PM Re: Rugged tabletizing [Re: Dalspeeklyrep]
Waragainstsleep Offline
Liquid cooling is really the only way to go if these are going to be waterproof. But you will need a heat sink which protrudes through the rubber layer. I suppose the simplest way to build what you want, would be to coat the whole thing in a waterproof layer of shock absorbing rubber, then run either heat pipes or water pipes through the case and the rubber, terminating on a large copper plate, ideally on the top of the screen. Maybe another one underneath. You'll need fins or something on the bottom one to allow air to circulate.
Top
#469567 - 11/25/06 04:14 AM Re: Rugged tabletizing [Re: Dalspeeklyrep]
ANonEMouse Offline
Here's my current thinking:
I've found a maker of water proof cooling fans. (Sunon 40mm x 40 mm x 20 mm)
I was originally thinking that I would use them to cool a liquid cooling radiator, but now I have a different thought:
If I build a copper heat sink "tunnel" through the middle of the case, I can seal it from the inside of the case itself, providing for airflow to cool the processor (and video I assume), but not allowing for a break in the water seal.
I'm thinking 5 of them pulling air out the top would allow for this.  Once I have the first 17", I will measure the airflow that Apple puts in it, then account for the possible failure of a fan by doubling it, as they can get blocked.
Top
#469568 - 11/25/06 06:46 PM Re: Rugged tabletizing [Re: Dalspeeklyrep]
Saillar Offline
Since money is not an object, Eliminate the Macbook cases and build larger cases out of Titanium ( light weight and strength) and use the cases as large heat sinks since it will be submerged in water and the case can conduct the heat away from the interior utilizing more and larger fans.  Since the cases will be waterproof, I would vacuum all air and find a gas that will not condense as the computer is brought up or down into a cooler ambient temperatures.
Eliminate the hard drive for as much flash memory as you can buy and fit into the enclosure.  Shock proof the logic board and optical drives with Teflon or nylon springs.
Of course the weakest link in this whole scenario are the waterproof gaskets in the cases and your need to have waterproof 1/4 turn thumb screws. Not to mention sealing up around the screen even if you use a poly-carbonate covering.  As for the functional touch screen being "not a problem", I disagree.  To rugadize the screen you will need to put something in front of it, polycarbonate, lexan or even safety glass and you loose the touch screen capabilites.  Unless you use some kind of Wacom device.  I have yet to see anyone match up a electromagnectic screen with a Mac except for Wacom in their Cintiq line. Of couse I would love to see a Mac Mod with a electromgnetic screen.
I think you would have better luck in posting to the Navy Seals, they probably have a an Underwater Windoze Tablet that they spent 10 million dollars to develop and could probably sell as surplus for a hundred bucks.
Top
#469569 - 11/25/06 08:58 PM Re: Rugged tabletizing [Re: Dalspeeklyrep]
OK, custom enclosures are going to help alot. Instead of messing about with fans and non-condensing gases, you could fill the enclosure with oil. Just immerse the components. Then you have better cooling, no need for fans or vents (you could use a small pump but there would be convection currents caused by the hotspots like the CPU and GPU), plus the oil would also give some good shock absorption properties.
I would make the lower half of the enclosure a seamless unit with rounded corners. No sharp edges or welds to spring leaks. Like the original bottom case without all the holes in it. A rubber seal around the top would allow you to simply bolt the top half on. Easy access for maintenance, easy waterproofing.
Titanium sounds a good bet, with rubber around it to help prevent big dents and aid in waterproofing. Can you work your secret touchscreen solution into a setup like that?
The biggest problem with doing things this way (as long as you can sort out the screen) is going to be the battery.
Top
#469570 - 11/26/06 05:33 AM Re: Rugged tabletizing [Re: Dalspeeklyrep]
ANonEMouse Offline
I'm not talking about waterproofing for underwater operation.  I'm talking about waterproofing for "oops, one of the tablets fell into the pool again"
I'm a bit leery about Titanium because I understand its strength is in its flexibility, which causes problems when talking about strength of the internals, which is not.
I've been thinking about the Aluminum in the MBP.  My 15" powerbook survived a 8 foot drop onto concrete with little more than some dents and a scratch on the screen.  If I planned on the same grade Aluminum, with about 3mm thickness (I think that the MBP is 1mm) I should be able to get a considerably stronger case without so much of the steel weight.
Also, after looking at the internals of the 17" MBP, I am thinking that I would be able to make the top out of a passive copper heat sink at the top of the unit, then utilize the existing cooling system to circulate the air internally.  Doing so, would effectively seal the electronics, but allow for heat transfer to the outer air.
I wonder what the smallest enclosed airspace Apple would want a MBP to be run in without it overheating.  Given that I am planning on making a metal enclosure that is 16"x11"x2", there is much more air in the unit to transfer the heat out of the heat sinks, and transfer it into the enclosure.
Top
#469571 - 11/26/06 07:07 AM Re: Rugged tabletizing [Re: Dalspeeklyrep]
ANonEMouse Offline
My touchscreen technology is not really secret.  I was planning on using a resistive screen from either trolltouch or KEYTEC.  My thought is that they are essentially waterproof to a few feet, as they are sealed to the surface of the glass.
I have included a picture to illustrate what I am currently thinking.  The central box (without the curved edges) is 17" wide (I increased the space to allow for holding it without touching the screen) 12" high, and 2" thick.  I have removed the back and top so as to allow internal viewing.  I have not included any of the electronics from the MBP yet, as I need to model them still.
In looking at the internals, I am wondering where and if I could have some longer wires made.  Specifically, the flex cable that attaches the IO board, as I would really like to place all of the ports on one side.  The non-orange wires will be relatively easy to replace.  I am also concerned that they may need to be a certain length because of timing issues.
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.097 seconds in which 0.066 seconds were spent on a total of 14 queries. Zlib compression enabled.
