Upgrading Core Duo to Core 2 Duo in MacBook/MBP [Re: progeek1] #469422 11/16/06 09:05 PM
B
boodle Offline OP
B
Ok, so it had to be asked!
We can't just slap a Core 2 Duo into our original MacBook Pros like you can with a Mini since the processor is soldered to the logic board. But is it flat-out impossible?
Re: Upgrading Core Duo to Core 2 Duo in MacBook/MBP [Re: progeek1] #469423 11/16/06 09:39 PM
M
mordaskyt Offline
M
Just speculation but as long as the chips are pin and voltage compatible a place like Daystar could prob pull it off.
PB G4 15" 1.2ghz - Pismo G3 400 mhz - iBook G3 500 "Jukebox"
"SawSmurf" G4 500 - Quicksilver G4 Dual 1ghz modding...
Re: Upgrading Core Duo to Core 2 Duo in MacBook/MBP [Re: progeek1] #469424 11/26/06 04:48 AM
9
987687 Offline
Where's the cache?
Where's the cache?
9
Daystar could probably do it, but I don't know where you would get the cpu. I don't think you could just buy one.
Re: Upgrading Core Duo to Core 2 Duo in MacBook/MBP [Re: progeek1] #469425 11/26/06 02:58 PM
W
Waragainstsleep Offline
W
You can just buy them.
