• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods
      » Hardware Mods » Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram.
Topic Options
Hop to:
#469028 - 10/08/06 02:41 AM Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
trend Offline
Hey, I am looking at getting a new macbook when the new ones come out (rev2). But want you'lls opinion.
I think my first 2 and probably only 2 mods are going to be:
1)Upgrade the ram to max it out 2gigs
2)Upgrade my hard drive to a 7200rpm 8mb cache HD.
Will my Hard drive upgrade make that much a difference from 5400rpm? Will I notice it?
Any other mods you'll suggest to get more performance?
thanks guys!
Top
#469029 - 10/08/06 02:52 AM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram [Re: bakarastre]
trend Offline
Or should I go with the macbook pro to get the
1) better graphics card
2) larger screen/higher resolution
3) 667MHz frontside bus (or does the macbook really have that fsbus as well.. but just doesn't say it)
4) ddr2 (or does the macbook have that as well.. but just doesn't say it)
...hmm.. This is going to be a desktop replacement.. but my current desktop has 2 1280x1024 screens.. and I am thinking with F9, I can use just one 1280x800 screen..
Edited by (10/08/06 03:06 AM)
Top
#469030 - 10/08/06 12:32 PM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
mordaskyt Offline
If you can afford the pro model obviously go for it. The dedicated Graphics card on the pro is hands down in a league above the macbooks. The ram is the single smartest upgrade you can do in regards to performance. As for the hard drive keep in mind that both laptops us serial ata drives, and the 7200 rpm drives can be pretty pricey. look here for a review of some of the current offerings on the market. http://www.techreport.com/reviews/2006q1/mobile-hdds/index.x?pg=1
PB G4 15" 1.2ghz - Pismo G3 400 mhz - iBook G3 500 "Jukebox"
"SawSmurf" G4 500 - Quicksilver G4 Dual 1ghz modding...
Top
#469031 - 10/08/06 03:18 PM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
macDeviant Offline
I've also been looking at buying a macbook pro (still don't like the name though) and you have the option for eiher a 100 gig 7200 rpm HDD or a 120 gig 5400 rpm HDD. If it's a desktop replacement i'd probably go with the 7200 rpm hdd. Keep in mind though, it will use up more battery life when it leaves the plug behind.
macDeviant
Top
#469032 - 10/09/06 01:58 AM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
trend Offline
Yeah.. I found the 7200rpm hds for laptop serial ata for around $110 on newegg for a seagate.. bit cheaper for other brands.
I think the extra money will be worth it.. but I really cannot justify a $600 price difference to get a larger screen and better graphics card.. I mean, it would be nice..
Top
#469033 - 10/09/06 07:18 PM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
zenstate Offline
Loc: Vancouver, BC Canada
I upgraded my mac mini's internal hd to a 7200 rpm and it made a noticeable difference.
2.94TB Total Storage
Top
#469034 - 10/10/06 12:42 AM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
trend Offline
Cool.. So I will def do the ram and hd upgrade.. but what about:
A) macbook pro's faster bus speed (or are both the same?)
B) better graphics card (yes, I know it is much faster.. but I don't do any gaming.. but I heard the new OS X ver needs a lot of 3d acceleration )
Top
#469035 - 10/10/06 02:27 AM Re: Thinking about getting a new macbook + upgrading HD to 7200rpm + upgrade ram. [Re: bakarastre]
trend Offline
Ok, to answer my own question
A)No both macbook and macbook pro have the same FsBUS
B) still don't know
C)(newly created) DVI output port on macbook is @ 1920x1200 pixels.. so This could tremendously help my large desktop needs.. Not sure if I should go large display and just use the one 1920x1200 display or should go dual monitors.. but will find that out once I get it smile
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.028 seconds in which 0.014 seconds were spent on a total of 13 queries. Zlib compression enabled.
