Loc: McKeesport, PA
Y'ever rub your hair or someone else's hair with a balloon just to see static electricity in action? I'm assuming there's a chance of static electricity building up normally when we're working on a mod. but, would putting hair gel in one's hair lessen the chance of static electricity building up? With hair gel the main ingredient is usually water anyway, plus it would make the hair sticky and/or stiff (yeah I know what i said..), so would it be as effectve or not?
"Tuesday's in the 80's? I was in bed by 8... ...and home by 11. OH!" -Quagmire http://emax4.fortunecity.com
Its no substitute for an anti-static strap. While one's hair does hold plenty of static, so does your skin. You know when you touch a car door or whatever and you get zapped? If you can feel it, its at least 3000V or so. It takes much less than that to destroy an IC or solid-state storage chip.
::) Now understand, This is my opinion. I have been messing around inside personal computers and Macs, as long as there have been personal computers and Macs. Or sometime in the '70s anyway. I take normal static precautions, such as touching the frame of the case befor I remove any componant. And storing my parts in those shiny anti-static bags. But I have never had an anti-static strap on my wrist.... ever. And I have never "zapped" anything. My openion again: if you touch the case frame, and don't go walking around on carpet, you will be at the same potential (electricaly) as the case and componants. And therfore you will not discharge any static to zap anything.
That said, If you normaly use a wrist strap keep using it! I don't want to hear from someone who lives in Qubec, in a house full of shag carpet, in December say" anil8tor said not to use a wrist strap, and I killed my mac"
Openions expressed in this post are those of the author, and do not express the openion of Macmod or any of its employees (except anil8tor) :P
Agreed Anil8tor. I used a strap once....and broke it. Havent used it since. I use a antic static pad, bags, etc. I too touch the case frame (while its plugged in), then unplug and remove components. You have to be smart about it, but there is overkill.
I would love to test the theory. Rub feet on carpet, hands on hair, whatever. Then man handle a pci card. Test it and find out whats up. I just happened to have an old scsi card begging to be zapped! >:D
The damge caused by zapping boards is not necessarily immediate or obvious. It can cause boards to fail further down the line, whereas they might otherwise have run fine alot longer.
Ok but if I want to be REALLY safe, I use jumper cables AND hair gel >:D
Edited by (09/24/0603:15 PM)
