• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Desktop Mods » auto-mount network drives and back up
Page 1 of 2 1 2 >
Topic Options
Hop to:
#468808 - 09/23/06 01:56 AM auto-mount network drives and back up [Re: MilPotCAR]
macDeviant Offline
okay i have my beige g3 and i want to use it as a server to back up my 5 other running machines at least weekly.
does anyone know of applescripts, freeware, not-so-freeware, or anything else that would allow me to mount specific volumes from each machine back them up then dismount the volumes all at a scheduled time? i've been looking and might have found something. but just wondering if anyone has foudn anything that would suite this very purpose...
i want to set up an auto-backup-server cause as much as i try i never remember to back up my hard drives.
smile i don't ask for much
macDeviant
Top
#468809 - 09/23/06 02:43 AM Re: auto-mount network drives and back up [Re: MilPotCAR]
krusher117 Offline
i auto mount my free 1GB smile
Ive attached the script.....look DOWN BELOW
Top
#468810 - 09/23/06 06:04 AM Re: auto-mount network drives and back up [Re: MilPotCAR]
krusher117 Offline
i know that doesn't help your predicament....lol
Top
#468811 - 09/23/06 07:42 AM Re: auto-mount network drives and back up [Re: MilPotCAR]
macDeviant Offline
i apprciate the effort  smile ;D lol thanks
Top
#468812 - 09/23/06 03:05 PM Re: auto-mount network drives and back up [Re: MilPotCAR]
Waragainstsleep Offline
You wouldn't have to become a scripting genius to do this.
You can use cron to run your script at the desired times, or simply run it as a login script Though this may slow the machine down for a little bit while you are trying to use it.
You can drop afp servers into your list of login items, then your script would only need to run a cp terminal command or two to copy the required folders onto the network volume. You might be able to do it with automator. Then you can use cron to schedule the backups, or you could attach a shutdown command on the end of the script, then when you feel inclined, finish using the machine, run the script and it will back itself up and shut itself down.
Don't try too hard on this, a family pack of Leopard will do this for you much better with Time Machine. And the server wouldn't need to be running Leopard in order to do it either.
Top
#468813 - 09/23/06 04:20 PM Re: auto-mount network drives and back up [Re: MilPotCAR]
soundmann18 Offline
I don't really know anything about writing scripts, but if you make the part that tells the computer to back itself up, you can set iCal events to run scripts, so you'd just make the event, tell it to run the script and repeat it however often you want.
War- do you know if you could use a non-apple box for the backup with time machine?  I've got an old P2 that i'm going to set up sometime soon for server-ing
Edited by (09/23/06 04:21 PM)
__________________
15" MBP late 2008
Top
#468814 - 09/23/06 04:22 PM Re: auto-mount network drives and back up [Re: MilPotCAR]
macDeviant Offline
well since it's a beige G3 i don't think i'll have to worry too much about trying to run leopard on it :)  admittedly this will be the first time to set up a server (also the first time i have had an extra computer to suit the purpose) what is "cron"? and i guess i should start looking up some commandline scripts/promts/commands (since i haven't used that much either)
thanks
Edited by (09/23/06 04:24 PM)
Top
#468815 - 09/23/06 11:00 PM Re: auto-mount network drives and back up [Re: MilPotCAR]
When you setup Time Machine, it asks you to choose backup destination. You don't seem to be able to drag your boot drive into the list, but afp servers show up automatically. My bet is if the Finder can mount it and write to it, Time Machine can use it.
cron is a system tool which runs 'maintenance' scripts at scheduled times. It can be modified to include extra scripts and to change the times it runs. There is a shareware app which provides a GUI front end to it, I forget what its called.
If you want to learn the terminal or scripting, I would search over on the oreilly network. They print many Mac textbooks and have alot of useful stuff on their site. The Jaguar based terminal tutorial is still close enough to be of use in Tiger.
the 'man' command can be used with another command as its argument to display the maual for that command. This tells you what it does and how it should be used. Open Terminal and type: "man cd"
This will display the manual for the cd or change directory command. press q to get out of a manual page.
Top
#468816 - 09/24/06 07:10 PM Re: auto-mount network drives and back up [Re: MilPotCAR]
zenstate Offline
Loc: Vancouver, BC Canada
i'm pretty sure apple has pre-written scripts that do this on their site.
2.94TB Total Storage
Top
#468817 - 10/15/06 11:41 PM Re: auto-mount network drives and back up [Re: MilPotCAR]
Anonymous
What are you looking to back up, the entire system, users folders, applications folders, shared folders?  Depending on how hard core you want to get the paid for Retropect Server can do it for you, but it cost money.  Let me know what you have found and I will suggest others.  The other possibility is  to try doing it with something like carbon copy cloner (shareware I think, but well worth it).
There are other options out there, but it all depends on how much you want to backup.  If I were looking to do the cheapest way it would be the free way of partitioning out the biege hard drives (uh.. how are you doing that by the way, connected firewire drive? or PCI SATA card?).  Once partitioned you could write a simple applescript or shell script to mount drives and DITTO the files (don't cp the files, doesn't always take the resource forks).
Let me know more of what you want and I'll share what scripting knowledge I can with you.
Chris
Top
Page 1 of 2 1 2 >
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.064 seconds in which 0.048 seconds were spent on a total of 14 queries. Zlib compression enabled.
