4G iPod Video Playback [Re: Sogyattaify] #468608 09/15/06 12:51 AM
K
kickassimacg5 Offline OP
K
I want to find out what makes the 5G iPod play video. Is it software or hardware? If it's the former, would I be able to hack the Apple firmware to run on a 20GB colour screened iPod
Naomi Robson Looks Horny ugh!
Re: 4G iPod Video Playback [Re: Sogyattaify] #468609 09/15/06 06:49 AM
W
Waragainstsleep Offline
W
Have a look at iPod Linux.
Re: 4G iPod Video Playback [Re: Sogyattaify] #468610 09/15/06 11:58 AM
K
K
I have tried it before but it didn't really suit me. It didn't play audio or video and it just didn't work. I might try out RockBox tonight and see if it's any better but otherwise I want to know if I can put 5G iPod firmware on the iPod
Re: 4G iPod Video Playback [Re: Sogyattaify] #468611 09/15/06 02:05 PM
Z
zenstate Offline
Z
I doubt that the cpu in the 4G ipod is powerful enough to play video well.  I know for a fact that apple started using a much faster cpu in the 5G so that it could decode mpeg4 and h.264.
I would imagine that even if you got it to play video that it would be jerky and not very enjoyable.
2.94TB Total Storage
Re: 4G iPod Video Playback [Re: Sogyattaify] #468612 09/15/06 07:43 PM
W
W
There's no way a 4G iPod will run 5G firmware. Its too different. Sorry.
Re: 4G iPod Video Playback [Re: Sogyattaify] #468613 09/16/06 04:15 AM
R
reLAXER564 Offline
R
I have a 20 gb ipod photo 4g and sucessfully got videos running on it. I installed linux and simply browsed to the video and played it. The problem with this you need a PC to convert the video the right format and size. This video also needs to be uncompressed which means it is a huge file. It is a novelty but not practical. Good Luck!
iMac G5 rev b. 1.8 2gb ram
Red iBook 14'' 800 Mhz G3
12'' iBook 1.07 G4
12'' iBook 600 Mhz G3
3.46 Intel Core Duo 2GB ram 500 HD
24 inch dell flat panel
Dual GeForce 8800 GTX in SLI
Re: 4G iPod Video Playback [Re: Sogyattaify] #468614 09/23/06 06:16 AM
K
K
Nup, I tried RockBox and although it is louder, it doesn't play video.
