Modding a HD to accomodate a LED [Re: miketheblogger] #468450 09/02/06 07:46 PM
E
emax4 Offline OP
E
I have two IDE hard drives, but none of them have external connectors for a(n) LED.  i've checked the spec sheet from the manufacturers, but the only thing I might be able to mod are the pins on the IDE port themselves.  There's a separate pin for read and write.  Would I be able to connect either one of these to a wire leading to an LED with the other wire leading to a ground pin (without blowing up the drive)?  Anything I would have to look out for ahead of time?  Thanks for the help.
"Tuesday's in the 80's?  I was in bed by 8... ...and home by 11.  OH!" -Quagmire
http://emax4.fortunecity.com
Re: Modding a HD to accomodate a LED [Re: miketheblogger] #468451 09/03/06 10:04 AM
W
Waragainstsleep Offline
W
The answer to this one is buried in the forums somewhere. You'll have to look I'm afraid.
Re: Modding a HD to accomodate a LED [Re: miketheblogger] #468452 11/21/06 04:41 AM
T
TCPMeta Offline
MacModder
MacModder
T
Pin 37 on the IDE ribbon cable.
+ of the LED on the cable and - on the gound to the v ground on a power supply morlex connector.
To live is to let die
