tell you how to convert DVD/other video to iPod [Re: kilsTroro] #467872 07/13/06 05:01 AM
T
tim_hortons Offline OP
T
If you need to convert to DVD or other video format files to iPod, you maybe interested in this step by step tutorial. http://www.nunufashion.com/software/SW_Tutorial.aspx?swid=9
Thanks smile
tell you how to convert DVD/other video to iPod [Re: kilsTroro] #467873 07/13/06 08:49 AM
W
Waragainstsleep Offline
W
I find Handbrake and MPEG Streamclip are more than ample.
Dvd [Re: kilsTroro] #467874 07/13/06 11:56 AM
T
Tayklor Offline
T
For Your DVDs you can use DVDXDV and you will nead a G4 Or G5 (or intel) to convert the Video.
PowerBook G4 1.67 1 GB 80 GB
Mac Mini 1.5 G4 512 MB
x2 Powermac G4 733
iBook G4 800 640 MB
PowerBook G4 667 512 20
iBook G3 500 In Parts
Powermac G3 B/W 350
2.13 Cel.D "hackintoch"
800 Pent.3 256 MB
400 Pent.2 128 MB
250 603
200 603
100 603
75 603
Random Parts
tell you how to convert DVD/other video to iPod [Re: kilsTroro] #467875 07/18/06 05:00 AM
T
T
If you use Mac, then Handbrake is a good choice. The above is suitable for PC users.
tell you how to convert DVD/other video to iPod [Re: kilsTroro] #467876 07/18/06 01:14 PM
M
modyourmac Offline
M
When going to another disc, MacTheRipper is sufficient. When going to another format, Handbrake does the job well too smile
Handbrake Lite for easy DVD to iPod conversion [Re: kilsTroro] #467877 07/19/06 02:11 AM
J
JediJoker7169 Offline
Awesome
Awesome
J
If you want the easiest solution (that I have found) for going directly from DVD to iPod format, try HandBrake Lite, made by the same guy who made iSquint. Get it here: http://www.isquint.org/handbrakelite/.
Cheers! :-)
- JediJoker
Current:
- "ProBook:" 15.4" MacBook Pro Core 2 Duo 2.33 GHz
- Mac Classic II
- Old PowerBook
Moved On:
- "The Book of Power:" 12.1" PowerBook G4 Aluminum 1.33 GHz
- Purple iMac
