iBook updated/downgraded [Re: Anonymous] #467260 05/15/06 10:42 PM
T
TCPMeta Offline OP
MacModder
MacModder
T
Well after some time I grown tired of my iBook chugging in Tiger so I downgraded to Mac OS X 1.3.9 Server. While I was at it I added the iCook software overclock kernel patch.
Some of us have tryed iCook before and had to re-load the kext and run the command to set the CPU clock. Well I added the commands in /etc/rc so it loads when os x loads up. Also I added in my .bash_profile a entry to show the cpu setting when I start the term.
To live is to let die
iBook updated/downgraded [Re: Anonymous] #467261 05/16/06 09:08 PM
G
griffer Offline
G
Why osx server? (just curious)
- iMac g5 2ghz, 1.5gb ram.
- eMac 1ghz (clocked at 1.27): 1gb RAM, Dual Layer Pioneer DVD +/- RW, 80 gb HD, 160 & 250 external Lacie FW HDs. And modified cooling.
- iMac 600 mhz
- b&w in atx case, with sata drives :p
- PowerMac g3 b/w - with atx psu
- PowerBook G3 Wallstreet
iBook updated/downgraded [Re: Anonymous] #467262 05/17/06 04:02 AM
J
JediJoker7169 Offline
Awesome
Awesome
J
I'm assuming you mean 10.3.9 and not 1.3.9? Unless, of course, Apple used two added digits in the days of 10.1...
Cheers! :-)
- JediJoker
Current:
- "ProBook:" 15.4" MacBook Pro Core 2 Duo 2.33 GHz
- Mac Classic II
- Old PowerBook
Moved On:
- "The Book of Power:" 12.1" PowerBook G4 Aluminum 1.33 GHz
- Purple iMac
