• AppleCentral Network:
  • Tech Support
  • Open Source
  • Apple News
  • Register Domains
  • SSL Certificates
  • iPod Deals
  • Mac Deals
  • Mac Book Shelf
  • AppleCentral Home
  • MacTech Magazine
    • About MacTech in Print
    • Issue Table of Contents
    • Subscribe
    • Risk Free Sample
    • Back Issues
    • MacTech DVD
    • MacTech Archives
    • MacTech Print Archives
    • MacMod
    • MacTutor
    • FrameWorks
    • develop
  • MacNews.com
    • MacNews News
    • Blog
    • News Scanner
    • Rumors Scanner
    • Documentation Scanner
  • Apple Expo
    • by Category
    • by Company
    • by Product
  • MacForge.net
  • Job Board
  • Advertising
    • Benefits of MacTech
    • Mechanicals and Submission
    • Dates and Deadlines
    • Submit Apple Expo Entry
  • User
    • Register new user
    • Edit User Settings
    • Logout
  • Contact
    • Customer Service
    • Webmaster Feedback
    • Submit News or PR
    • Suggest an article
  • Connect Tools
    • MacTech Live Podcast
    • RSS Feeds
    • Twitter
You are not logged in. [Log In] AppleCentral » Forums » Mods and Hacks » Laptop Mods » Hardware Mods » Building a Pismo
Page 1 of 4 1 2 3 4 >
Topic Options
Hop to:
#467161 - 05/09/06 08:57 PM Building a Pismo [Re: Anonymous]
shadowboxer47 Offline
So, as some of you know, I've been thinking about building a Pismo completely from scratch. I think it will be a cool project. Of course, I need a parts list and some general guide. Other than that, any suggestions and/or comments?
Top
#467162 - 05/09/06 09:34 PM Intrigued [Re: Anonymous]
mordaskyt Offline
As a shamless Pismo lover (I use mine instead of my G4 1.2 GHZ iBook) I am very interested, what, exactly do you mean? Part by part, to build a stock/upgraded Pismo or using the Pismo case with more modern "guts"?
PB G4 15" 1.2ghz - Pismo G3 400 mhz - iBook G3 500 "Jukebox"
"SawSmurf" G4 500 - Quicksilver G4 Dual 1ghz modding...
Top
#467163 - 05/09/06 11:01 PM Building a Pismo [Re: Anonymous]
Waragainstsleep Offline
Do you have any parts yet?
I can give you a good list to start with at least, just from memory:
Top Case inc. Trackpad and Speakers;
Bottom Case;
Front Screen Bezel;
Rear Screen Bezel;
Logic Board;
Battery Charge Board;
AC/Sound Board;
CPU Module & Heatsink;
PCMCIA Card Cage;
Airport Card Cable;
LCD Panel (There are two different ones, they might use different displaycables);
Display Cable;
Inverter Board;
Inverter Cable;
Modem Board & RJ11 Cable;
Airport Antenna Cable;
Microphone & Cable;
Keyboard;
Optical Drive Module;
Hard Drive Cage & Cable;
Battery;
Hinges;
Clutch Cover with Power Button;
PRAM Battery;
Port Cover (usually with the bottom case);
Heat Shield;
Fan;
Rib Frame (often found with bottom case on eBay);
Obviously you will need a hard drive, RAM (PC100 or 133 SDRAM) and your choice of optical drive to fit in the module. And screws to hold it all together.
If I have missed out any parts, they will mostly be included with one of the other parts on my list.
Upgrade Options are as follows:
G4 CPU up to 550MHz or so;
G3 up to 1GHz or so;
RAM up to 1GB;
Hard Drive up to 128GB I suspect;
Will happily run a DVDRW;
PCMCIA Expansion;
Not sure if you can overclock the Rage128 GPU or not;
High-Capacity Battery;
Should get you started at any rate.
Probably would be too pricey at the moment, and the biggest one I found was only 1GB, but I have been wondering about using a PCMCIA flash card to boot OS X on an older PowerBook. I figure 8GB of flash would give you a nice big, fast scratch disk.
Top
#467164 - 05/10/06 12:36 AM Building a Pismo [Re: Anonymous]
I mean part by part, sir. All the way!
Pretty daunting, but I think it will be fun. I'm going to be asking for everybody's help on here because, in all honesty, I've never touched a Pismo but I love them to death...
kinda like a crush.... err... maybe
Top
#467165 - 05/10/06 12:37 AM Building a Pismo [Re: Anonymous]
waragainstsleep,
Thanks for the list. I'll make that my starting point. Right now I'm cruising on eBay and comparing part prices. I want this to be as cheap as possible.
Eventually, I want it completely upgraded. It would be cool if I could get the now defunct G3/1GHz, but they're super rare and super expensive. I would like that to be an eventual goal. If not, I'll get the G4
Top
#467166 - 05/10/06 01:45 AM Building a Pismo [Re: Anonymous]
mordaskyt Offline
The Apple service manuals have the exploded view at the end which is a great visual reference.
http://www.applerepairmanuals.com/#portable
Top
#467167 - 05/10/06 02:12 AM Building a Pismo [Re: Anonymous]
zenstate Offline
Loc: Vancouver, BC Canada
pismo is the best G3 portable in the history of the world. you can even get G4 1.9ghz upgrades for them now.
good luck and happy building!
2.94TB Total Storage
Top
#467168 - 05/10/06 03:21 AM Building a Pismo [Re: Anonymous]
maestro Offline
1.9mhz for a Pismo? Havent heard of that. I know that there is such a cpu for Tibooks. I have had great success with a FastMac G4. Now if I could get around to getting another battery.
Top
#467169 - 05/10/06 07:13 AM Building a Pismo [Re: Anonymous]
griffer Offline
This is one crazy idea, but weirdly fascinating laugh. Gonna look forward to following this project.
- iMac g5 2ghz, 1.5gb ram.
- eMac 1ghz (clocked at 1.27): 1gb RAM, Dual Layer Pioneer DVD +/- RW, 80 gb HD, 160 & 250 external Lacie FW HD´s. And modified cooling.
- iMac 600 mhz
- b&w in atx case, with sata drives :p
- PowerMac g3 b/w - with atx psu
- PowerBook G3 Wallstreet
Top
#467170 - 05/10/06 02:07 PM Building a Pismo [Re: Anonymous]
zenstate Offline
you're right. its for the tibook. wasn't thinking..
Top
Previous Topic
View All Topics Index
Next Topic
Tweet
Preview
Moderator:  Acumowchek
Print Topic
Switch to Threaded Mode
   »Apple World
Marketplace
   »Deals and Special Offers
      »Expired Offers
   »Trading Warehouse
Mac
   »Hardware
   »Software
   »Windows and Virtualization
   »Cloud and Online Services
Mobile Technologies
Mods and Hacks
   »General Mods
      »Techniques
      »Miscellaneous
      »Mod Logs
   »Laptop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Desktop Mods
      »Case Mods
      »Hardware Mods
      »Misc. Mods
   »Peripheral Mods
      »iPod Mods
      »Misc Mods
   »Software Hacks & Mods
General Discussion
   »Site Feedback & Issues
   »Stan's Lounge
   »Soapbox
Now Software Support
   »Announcements
   »Now X
      »FAQs
      »Discussion
   »Now Up-to-Date & Contact
      »Community Help
      »Tips and tricks
View profile
Send a PM
Add to your Watched Users
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View posts
View profile
Send a PM
View homepage
View posts
Board Rules · Mark all read
MacTech Only Search:
Community Search:
  • SPREAD THE WORD:
  • Slashdot
  • Digg
  • Del.icio.us
  • Reddit
  • Newsvine
Main office: 805-494-9797
Generated in 0.057 seconds in which 0.036 seconds were spent on a total of 14 queries. Zlib compression enabled.
