My next door neighbor bought a 4 wheel quad, and after ripping it apart, he gave me a set of LED lights that came off of it. So after doing some research on what the lights were, i figured i would spice up my sawtooth a little. The LED lights are 6 (3 across in 2 rows) and they hook up via 12 volt. he gave me the LED's, the fuses and all the wiring for them. So, i decided to start the mod.
Here i double sided taped them to the bottom of my case, and zap strapped the wires so they go into the bottom of my case nicely. http://f5.putfile.com/5/12709164618.jpg
After rerouting the wires so they go to the top of my tower, i stripped the wires so that they show the red and black wires. http://f5.putfile.com/5/12709161162.jpg
Here i attached the end caps for the fuses so that if there is a surge of power, i blow the fuses first and not the LED's. http://f5.putfile.com/5/12709211895.jpg
I used the end plug from an old PC motherboard and filed it down so that it would mate up with the 4 plug 12v that sits above my power supply. I also hot glued the wires to the plug so that i wouldn't cause a short anywhere. The hot glue is rubber, so no conductors. http://f5.putfile.com/5/12709223298.jpg
Here is a shot of everything put together and ready for the covers to be put on. I like how this looks so neat and tidy. http://f5.putfile.com/5/12709225658.jpg
LOL... It looks positively awesome, but whether it really is too bright for me or whether it just came out that way in the photos, it made me want to hide in the closet.
Cheers! :-) - JediJoker
I'm Brazilian and don't speak english very well, but in next time i'll put step by step case modding this mac...
So... RedDragon, please... I see, you have Nvidia 6200 card in your mac? can you send me this rom file? I'll try to flahs a NV6200 AGP card (at now only I do in FX5200) to my mail: rubensx@superig.com.br thanks for your help
best regrards!
FrankenQuicksilver - G4 Dual 800mhz Quicksilver - 1,5g ram - HDs 30g e 40g - Video FX5200 ULTRA 128mb - CoolCase PC mod...
Welcome to brazillian way of life... upgrades and mods is the key!
Sorry, I can't. My card was specially made from the people over at strangedogs. You would have to go over to their website and talk to some of the people there about your 6200. I will not give out the rom. It's not my place to do that. If they found out that i did, i would be in big trouble with many people, so your on your own with that one. Sorry.
RedDragon sorry i'm don't know this a strangedog rom.. .i'm in this forum too, but no one can send me that card (maybe afraind of Brazil??? hehehe) but ok! thanks for explain... i'm waiting until someone cam send a flahed card to me here in brazil and acept PAYPAL
tanks
Awsome! looks very cool! Nice work! I love a good light show.
