#466856 - 04/11/0608:19 PMMDD Big Plans Progress Report
[Re: Hoffman_A]
waamatt
Loc: San Francisco, CA
So, I still haven't done my OCing (or ordered fans - something I need to do more research on to find the "right" ones)... But, in addition to the hard drive I added right when I got the computer, I just installed 2GB of PC2700 DDR RAM (Crucial brand). It's CL 2.5, 64x64, Non-ECL, Unbuffered, 184-pin.
What I find VERY interesting is that the System Profiler shows the speed as PC2600-25330. NOT PC2100, which is the stock RAM's speed. So, without even OCing, I'm getting more bang for my buck.
All 2GB after shipping cost me $150 and change.
I haven't actually tried using any apps, but first boot after install was slow (as I expected), and everything is running A-OK. Time to try Photoshop, iTunes, World of Warcraft, user switching, and some other things and see how it all goes.
Next step: Fans and overclocking. (After that? Graphics card.)
#466858 - 04/12/0612:44 AMMDD Big Plans Progress Report
[Re: Hoffman_A]
waamatt
... Well... I would have... My budget is pretty limited, and the CAS2 RAM was like an extra $20 a stick, so... $80 vs. minimal performance gain? I'll keep my $80.
Hey, do what you can. You're better for it. I for one have a hard time upgrading any computer without going "all the way"--sometimes to points of idiocy. More power to you!
There are two ways to do everything. You can buy more for less or my less for more. I would buy less, faster memory personally, but different strokes. You will get more of a performance boost from the oc anyway. Go for it! I have a drinky before hand to keep my hands steady....just a tip for ya.
PC2700 is the way to go since G4 processors cannot process RAM any faster. On a whim, due to the Mac mini's (original) supporting PC3200 I called Apple to confirm this. Was not too sure if they came out with some miracle tweak to the processor. Mind you, this was the first day everyone got their mini's so there was no documentation.
Anything faster than PC2700 is wasting cash. Max out since it's cheap enough now.
Apple just throw 3200 in the Minis because they were already buying piles of the stuff to go in G5s. Its all about the volume. 2700 would probably have cost them more.
#466863 - 04/14/0602:34 PMMDD Big Plans Progress Report
[Re: Hoffman_A]
waamatt
I agree with Waragainstsleep on the use of 3200 in the first minis. A similar reason is probably behind the use of PC2100 in the original MDDs even though the 133MHz bus will handle up to PC2600 just fine.
One question before I order a copper heatsink: It'll work in ALL dual processor MDDs right? I don't want to spend $65+S&H and then have to deal with returning the thing.
Notes on performance after 2GB of RAM installed: Wow, so little difference. The aforementioned user switching boost continues. Apps hardly seem different. World of Warcraft gets less frame rate stuttering from areas that previously would've resulted in lots of VM paging. It still happens, but it's so much more tolerable. Despite that, frame rates are not noticably higher. The real boost there will be from a faster CPU and better graphics card. Safari, Mail, Adium, iTunes - they all feel exactly the same. Eh, I'm still glad I maxed out my RAM. Maybe in a year I'll start replacing it with faster (lower latency) memory just 'cause...
#466865 - 04/17/0611:50 AMMDD Big Plans Progress Report
[Re: Hoffman_A]
waamatt
War, I believe you're right about the non-existance of PC2600. I'll check the one that was in my machine already that was showing up as 2600. But, for whatever reason, 2700 in a system with a 133MHz bus is showing up as 2600. (I guess that's the double data rate talking.)
