Flashing An nVIDIA GeForce Go5200 FX [Re: Anonymous] #466699 03/26/06 11:54 PM
J
JediJoker7169 Offline OP
Awesome
Awesome
J
Can this be done feasibly by someone who on a scale of 1-10 in computer mechanics is a n00b? I'm looking for a little bit more performance out my PowerBook, especially when it comes to gaming. If only there were something akin to ATiccelerator, but alas, no one has written an nVIDIAccelerator.
Cheers! :-)
- JediJoker
Current:
- "ProBook:" 15.4" MacBook Pro Core 2 Duo 2.33 GHz
- Mac Classic II
- Old PowerBook
Moved On:
- "The Book of Power:" 12.1" PowerBook G4 Aluminum 1.33 GHz
- Purple iMac
Flashing An nVIDIA GeForce Go5200 FX [Re: Anonymous] #466700 03/27/06 06:14 AM
M
MikeMan Offline
M
Does aticcelerator support Nvida, i know ati tool (for windows) does
AMD Athlon 64 3000+ @ 1.9ghz, RaidMax X-1, 520W RaidMax PSU, 1GB A-Data DDR400 Ram, DL-16x LG DVD Writer, Gigabyte GA-K8N-SLI, 200GB Sata, 2x 20GB PATA 1x 40 PATA, Nvidia 6600 256mb
Flashing An nVIDIA GeForce Go5200 FX [Re: Anonymous] #466701 03/27/06 06:48 AM
W
Waragainstsleep Offline
W
Graphiccelerator as its now called will overclock an AGP 5200. Don't see why it wouldn't do yours too.
Flashing An nVIDIA GeForce Go5200 FX [Re: Anonymous] #466702 03/27/06 07:13 AM
J
Awesome
Awesome
J
Unfortunately, there's no support for the Go5200 in Graphiccelerator... Yet. I emailed the developer with the ROM I dumped, and hopefully, he'll add support... Sometime... After all, it is the card (to my knowledge) that was used in all of the 12" PowerBook G4s.
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
Flashing An nVIDIA GeForce Go5200 FX [Re: Anonymous] #466703 03/28/06 07:29 AM
J
Awesome
Awesome
J
As it turns out, according to the developer, ROM dumping and flashing with built-in video cards doesn't work. It has something to do with the dumped ROMs always being "corrupted."
Cheers! :-)
- JediJoker
Current:
- Mac Classic II
- Old PowerBook
Moved On:
- Purple iMac
