Just about to buy a new hard drive to go in my MDD. Its about time I got some proper reliable storage, to supplement my pile of old well-used drives. I'm looking at something in the 300GB sort of area. I have basiclaly narrowed it down to two options:
A 320GB WD Caviar 7200rpm with 8MB buffer, or a 300GB Maxtor Diamondmax 7200rpm with 16MB buffer for about £5(~$9) less.
Just wondering how much difference (if any) the buffer is likely to make in an MDD FW800. I plan to use this a the boot drive, since it will be faster and more reliable than any of my other drives. I would prefer the drive to be as fast as possible, but if the bottleneck is the bus rather than the drive, I will go for the slightly bigger one.
Looks like the 320 is ATA100 with a seek time of 8.9ms. The 300 is ATA133 with a seek time of 9ms. The bus is ATA100, so I'm guessing the 320 is the way to go. Will the buffer size make any difference in this case?
I've owned WD and Maxtor drives without noticing any problems with either one. I'd go for the lower priced drive. It's just a bonus that you can get double the buffer RAM for less. I've only had 8MB buffer so I can't say whether you'll "notice" the difference. I really don't understand how that kind of memory works anyways. If I have a 250GB HD what good does a 8MB buffer do for me?
Maxtor makes the fastest hard drives you can buy. Yeah, they are.....72mbs for sata II. That is WD Ratpor territory for A LOT less and A LOT more room. I own drives from Hitachi, Seagate, Western Digital and of course Maxtor. Unless I find a deal that I cannot turn down, I always buy Maxtor. The Diamondmaxs are the same as the MXIII but with a shorter warrenty. I buy MXIIIs and suggest you do the same. For the price of a 150gb Raptor you can Raid two 300gb MXIIIs for speeds that bring hd throughput out of the dark ages!
The Buffer works just like the cache on your cpu, the drive tries to anticipate what the next data is that you will need read, and loads it into the cache. If it gets the right data then the access time is reduced significantly. This makes the drive appear faster. The greater the buffer the better the chance of loading the correct data for the next read.
RAID is not really an issue until I finish building my Xserve. This drive will just give me room to play with until then. Thats where the real storage is going. I just want to know if the difference in buffer will be such a difference on an ATA100 bus.
If the speed was going to be the same, I would go with the 320. But if it will make things noticeably snappier, I will go with the 300.
Apparently the 300GB Maxtor has NCQ as well. Is that likely to make much difference?
