If you wanted a completely black iBook G4, you could send it into ColorWare and have it painted Jet Black, figure out how to color the trackpad, replace the keyboard, and hell, why not color your Apple while you're at it? It would look great in Red, Black, or Classic Apple. And by that same token, the guy with the white TiBook could replace his keyboard with an iBook G4's. Then, of course, both would still have to deal with the cable routing problem... :rolleyes:
Edited by (02/20/0611:39 PM)
Cheers! :-) - JediJoker
