Hey anybody know how to mod a G3 B&W button board to work with an agp graphics g4 motherboard (the one with the internsl firewire 400 port). If not does anybody have a g4 buton board and cable that they are willing to give to me or sell at a reasonable low price.
The G4 PCI uses the same front panel board as the G4 AGP, but the same logic as the B&W G3. I would imagine the G3 board should therefore work. Can't promise you that though.
I am pretty sure the connectors are different on them. Anil8tor modded his to work with it. Hopefully he will chime in and give you some advice on how to do it.
