You have a lot of good choices there. Really, the problem with ATX cases is that they look so PCish. However, if you're able to pull off a nice Mac look, that would be great!
I have ordered a G5 case clone for 30 bucks. I can always add a mesh cover to it. I may paint the case black or silver when I get it. The case is red. Right now I have the water cooling kit on my Gaming PC to test it out. Doesn't seem to cool that much. The CPU's temp right now is 76.1*F and before it was at 89.7*F. I'll think about the sawtooth case parts. The only thing that is messed up with the sawtooth case cover is the side panels when I atempted to remove the paint to make them clear.
I have found out something else with the water cooling kit I bought. Since i'm testing it as we speak with a AMD Athlon 64 2800+ at the stock speed of 1.8GHz the CPU gets around 75*F to 76*F and when I play a video game the CPU temp jumps to 80*F to 90*F. Pretty much the same temps I can get with out the water cooler. I have found a little idea fo a external water tank that will help things. A iglo water cooler with ice and water. It's working quite well and there is no condation at all. it has lowered the temp to 46.2*F and with a video game the max temp has risen to 53.7*F. Not as cool as a fridge's temp (40*F to 32*F).
