TCPMeta is right about it being a parallel(IEEE 1284) hub. I would not suggest using it as a SCSI interface as the pinouts are completely different and the board, depending on how advanced that hub is, would route the signals to the wrong pins. You could try and get lucky, though I doubt it would work at all.
Thanks, I guess... now I'm really confused :S I'm gonna take it to a friend of mine in the weekend, he still uses both parallel and scsi. I'll keep you posted.
