I have just received my Apple 5260/100 from a friend. It has not ethernet nor modem ports. Is there any upgrades that anyone knows of that I could run. I tried to load 9.2, but it only will run up to 9.0. If anyone has 9.0 software, I would be more gladly than to buy it off of you.
any ideas?
14' g4 ibook-1.33ghz/768mb/60gb/Tiger (up for sale, PM if interested)
"I wanna be a boat. I wanna learn to swim. Then I'll learn to float. Then begin again." -jawbreaker
:blink:
9.1 is going to be the newest one you can operate, though if you can't play DVD's, don't care about iTunes, or anything like that maybe tedj's advice on 8.6 should be followed.
Well, would anyone happen to have the software that they could copy it as an image or I could just buy the software off of whoever has it. At the tops, it will run 9.0, but 8.6 will be more than fine.
