Yes it does have the 2mb cache and im sure you miss it! Im not exactly sure how to get it running. Did you google it? Try http://www.macsales.com. They sell a ton of upgrades and have a lot of info on them that may help you out. I know the upgrade manufacturers have software for your problem. Good luck. -maestro
