At 16x DL, it is most likely a Pioneer DVR-110 (Or maybe a 109 - the biggest difference is firmware anyway). It could be a different one, but why not just get a standard DVR-110? They are cheap at the moment, the drivers are probably on the Pioneer site, and it will work fine if you later decide to pull it for use in a Mac.
I suspect some kind of burning app like Nero, or something from Roxio would certainly be able to run it under Windows.
Please? Somebody? Anybody? I'd like to know before I just start scrubbing away...
And I'm assuming paint designed for scaled model and remote control cars will work just fine for a new paint job... Am I correct? There's a hobby shop conveniently located where I could pick some up. Or do I need special stuff like Krylon?
Cheers! :-) - JediJoker
I just discovered that I will most likely be required to go with watercooling, unless there's a good enough fanless hetsink, which I doubt. I hope I can find a kit that will fit internally. I guess my best bet is probably to wait until I have everything else put together in the case.
