I've got a iMac 233 MHz. Looks like the CPU can be upgraded and/or overclocked. The question: do I need a bigger heatsink for faster CPU? And, is it better if I use thermal paste or is it unnecessary?
A bigger heatsink might be a good idea, but even more importantly, the case will need better ventilation. You should consider installing at least one fan at each of the vents (top and back).
Cheers! :-) - JediJoker
First off, welcome to MacMod!
A fast CPU often means a hot CPU. The cooler the CPU, the more efficient the system. A bigger/better heatsink can help in this. Unless you're overclocking or doing it just for kicks, the oem heatsink should be sufficient.
When applying a heatsink, it is always best to use thermal paste.
Post edited by: shadowboxer47, at: 2005/11/30 21:51
Unless you lap the heatsink, always use thermal paste. I recommend arctic silver. As for the heatsink, bigger is always better and you should make sure there is airflow over it. -maestro
Yep. Thanks for replies. I realize now my question wasn't formed very well. Actually I'd like to know if those iMacs with faster CPU's came with bigger heatsinks than my 233 MHz?
After the 233MHz systems of the iMac Apple basicly rebuilt the iMac. Changed the logicboard layout so the CPU was on the backside of the logicboard and used a rizer heatsink that went from the CPU to the case chasie. So really and turely the case was part of the heatsink.
