Ok, so I had a BT 1.1 usb module and I just got the Wacom BT Tablet and I need 1.2 for the transfer rate and sustained connectability. So, I bought an Apple internal BT module and just installed it. Then I realized that there is an external antenna that I need to get the reception.
Now, I find myself trying to find a decent deal on one. eBay with no luck and the web seems to have pricey offerings...
How bout some rabbit ears! Kidding. Did you try going to Best Buy and seeing what antennas they have? By the way, I take it that the original tooth had no antenna? -maestro
well, I bought the module off ebay. There is an external antenna port on the G5 case. It didn't come with this antenna and it is needed, the reception is really poor without it.
I get like 2-3 feet tops :angry:
muhahaa, I just worked up a paperclip antenna and jammed two ends into the slot so that it created a somewhat snug connection with the internal antenna. It increased my range by about 30 feet!
Would still be nice to get a better solution, but this works for now I guess
Speaking of G5s and Bluetooth, is it possible to buy and install a module on the new dual-core ones? I checked when we bought it and Apple won't do it for you, nor do they sell the module so you can do it yourself. There is no problem with the antenna with the new ones; it's encased in plastic and built into the back of the case, but I can't seem to find the module or the connector on the motherboard.
