Well I got WindowMaker to run on top of Tiger 10.4.2
This is what I done to get it to work.
Installed the SDK to 10.3.x and 10.4.x DarwinPort X11
I installed window maker thru Darwinport. Then went into the X11 prefs and added a app launch with the command wmaker. I rebooted and launched it. That simple! I'll post a pic as soon as I can.
Very nice! I got enlightenment running on my old OS X install, though didn't like how it worked. Windomaker is a good choice. I did use it with my old Slackware installs from the 8 days, though those were different times.
