i found an old Sony VAIO from my PC daze that im going to transform intoa Das but one minor modification recently, i disassembled my mouse, and rubber sprayed the body and buttons much grippier now i am going to rubber coat the keys! im just going to soak the keys in alcohol for now so if anyone has an ideas...post!
Sounds cool, but i wouldn't want anything gripping my fingers like that. Just take into mind that the plasti dip can dry pretty thick and that may cause friction between the keys.
the stuff i got can be pretty thin, two coats will adequately coat the keys and leave plenty of space without sticking the reason im using rubber grip is because i have slight nerve damage to my right hand while i can still type fast, my fingers slip when i hit keys from time to time thus, making me make spelling errors i hope this rubber coating will solve this
