As many of you know, my current project is my 9600/200. I'm doing some pretty heavy modifications. When it is finished, it will arguably be the fastest pre-G3 Macintosh in existence. The current PS is 350—not enough for my plans. Here are the current/future specs:
Processor Powerforce 750GX 1.0Ghz G3 (OC @ 1.3Ghz) OR Crescendo PCI 800Mhz G4 (OC @ 1 Ghz) Hard Drives: SCSI 30 gig ATA 10k 40 gig ATA 7200 40 gig RAM 1.5 Gigs Media: Superdrive Video: Radeon 9200 PCI Radeon 7000 or similar Cooling Fans w/ fan controller Some internal/external water cooling system (yet to be determined)
There are a lot of other little things, but this gives you a decent picture. I'm aware that there are many different types of water cooling systems out there and that's a pretty big variable in deciding wattage, but at the moment I simply haven't decided what to use. I'll have a better idea once I decide on the processor and I get my case in.
I'll probably be using an ATX PS (fun with conversions!). Any suggestions as wattage and brand?
Post edited by: shadowboxer47, at: 2005/10/29 09:59
