I'm probably wrong since the only external dive i've worked on was tearing it apart, but the controller chip might not be able to handle 160gb. It could still have that issue of only seeing about 120gb. I forgot what that porblem is called though. BTW if the controller can handle it it looks like you could fit a second hard drive in there :cheer: .
"A wise man speaks because he has something to say. A fool speaks because he has to say something."
"I do not condone, nor suggest the use of PCs."- Maestro
Its got to be the IDE controller you used, never heard of it happening to an external drive but then I have not had much experience with large (120gb+) drives. Older ATA controllers don't recognize drives larger than 127gb. The 127 number cannot be a coincedence. By the way very nice job, that is an instant classic!
Weird - I was just about to say that it's cuz HD manufacturers call 1 GB 1000 bytes, while programmers call 1 GB 1024 bytes (2^10). And so there is always a discrepency between what you're told and what you get, but then I checked my 160 and I have 152.55. And now doing 160,000 / 1024 on my calculator I get 156.25. So we'll just say the man is screwing us.
